Engine Starts then Stops--'94 Suburban
Old Jan 29, 2014 | 10:16 PM
MRC Chevy's Avatar
Default Engine Starts then Stops--'94 Suburban
This happened last year and the dealer couldn't find any problem. I've got a 5.7L 8cyl, 4WD. It acted like this twice today. Starts up, chugs and shakes, then shuts off. I then started it up and it did it again. But the third time was a charm, and it ran fine. Is this a battery problem? Ethanol gas?
Old Jan 30, 2014 | 10:52 AM
I'm guessing a fuel supply issue. Possibly a small amount of moisture in the fuel.
Old Jan 30, 2014 | 01:04 PM
NullHead's Avatar
Is it only cold weather? i wonder if its not an icing throttlebody or a sticking iac
Old Jan 30, 2014 | 09:04 PM
MRC Chevy's Avatar
It actually does it at all temperatures, even near 100 degrees like last summer.
I'm thinking maybe it's the cheap gas after all? I filled up with "Circle K" 87 octane last time.
Old Feb 1, 2014 | 02:15 PM
NullHead's Avatar
EGR valve not closing, causing exhaust to choke out engine? Then the valve finishes closing on the second time cranking? My old 89 pickup used to do the same thing sometimes, but it always has this really long crank that I couldn't figure out either. I didn't really care enough to figure it out though.
I guess you'd have to have a fuel pressure gauge on it to see what's going on when it stalls out like that.
Old Wrench
Apr 1, 2014 10:33 PM
btelin
20
Jun 26, 2011 08:42 AM
sseeya2001
May 26, 2010 12:29 PM
webrik33
May 14, 2008 04:56 AM
jsh757
10
Mar 19, 2008 07:44 PM
