Ext Cab side windows leak water
Hey guys, I appologize if this is a subject that is frequently discussed, I tried the search function and didn't find anything. Basically like the subject line says, both my side windows in the ext cab leak water when I go through a drive through car wash. We had a few bad rain storms come through here over the past few weeks andthey did not leak at all during the rain storms only when I go through a car wash.
I thought if this was a common issue that you guys could tell me how to fix it. It's a 99 ext cab. thanks in advance Chris |
RE: Ext Cab side windows leak water
I never heard of it but you could get new weather striping. I dont know if it will help any.
Thanks for the quick reply. I looked at the old weathering it looks like it is in good shape. The window when in the closed and locked position do not seem like they close very tight? A fiend of mine has an 01 ext cab and when his is closed and locked they actually pull in what appears to be about an 1/8" tighter than what mine does?
Does the weathering (even though it looks good) does it relax over time and loose its compression? |
HERE IS WHAT YA DO..OPEN EM UP..GET A RAG AND A PAIR OF CHANNEL LOCKS..using the rag over your pliers not to scratch paint,ease the metal of the cab (on the hinge side) inward...just a little at a time...ease that metal edge back in...try t and see if she snaps tighter for ya
In addition to what Argon has levied upon you, I would also like to point out that maybe the car wash shouldn't be used so frequently if the leaking persists.
ORIGINAL: Argon HERE IS WHAT YA DO..OPEN EM UP..GET A RAG AND A PAIR OF CHANNEL LOCKS..using the rag over your pliers not to scratch paint,ease the metal of the cab (on the hinge side) inward...just a little at a time...ease that metal edge back in...try t and see if she snaps tighter for ya ORIGINAL: MajorSilva In addition to what Argon has levied upon you, I would also like to point out that maybe the car wash shouldn't be used so frequently if the leaking persists. :) |
I guess I will try this too, mine doesnt really leak water but is pretty noisy on one side while on the highway. hopefully that will do it
yes..the glasses need to snap tighter..the only way to make those shut tighter is to "bend" the frame edge inside a tad..it only take a little.
