Few electrical problems on 2001 GMC Sierra
Old Dec 1, 2012 | 12:14 AM
RustyFordLover's Avatar
Default Few electrical problems on 2001 GMC Sierra
I have a 2001 GMC Sierra 1500HD with the 5.3 in it.
The first problem.
My tow/haul mode button on the shifter handle doesn't work. No light comes on, and the truck doesn't shift down, or rev higher between gears. Where is a good place to start trouble shooting?
And another problem. The dash lights in my headlight switch, and in my heater switch control don't work. Good place to start trouble shooting that?
Thanks
Old Dec 1, 2012 | 01:04 AM
Your Tow/Mode button. I would start with the fuses
Your headlight and Heater light is a simple bulb replacement.
Old Dec 1, 2012 | 07:59 AM
I have already checked those, everything is fine, including the relays.
Old Dec 2, 2012 | 05:31 AM
acnas's Avatar
tow haul inop from broken wires in column usually at base of shift lever. Heater switch wont work? No hot/cold? blower? vents? or lights? Headlamp switch could just be the switch?
Old Dec 2, 2012 | 07:36 AM
Everything works fine. Just the illumination lights don't come on.
Old Dec 3, 2012 | 05:15 AM
acnas's Avatar
The bulbs are probably burnt out. I think they are soldered to the circuit boards.
Old Dec 3, 2012 | 08:44 AM
I think the little bulbs are burnt too.
When my fog light SWITCH BULB burnt out I had to solder a new bulb after I figured out how to get to it
Old Dec 3, 2012 | 10:38 AM
Mine has the little snap in bulbs. I have already changed them.
Old Dec 3, 2012 | 09:40 PM
U da man
Old Dec 5, 2012 | 09:08 PM
but it didn't fix anything :/
