flex fuel performance
Old Feb 4, 2008 | 12:45 AM
white06's Avatar
Default flex fuel performance
i just bought my 06 and found out it has the flex fuel motor in it can i still use all the normal performace bolt-ons from a 5.3L? and does anyone know how big the fuel tank is i put almost 23 gallons in it the other day and it was at a 1/4 tank it just does not seem right.
Old Feb 4, 2008 | 05:37 AM
Argon's Avatar
Default RE: flex fuel performance
probably a 8 gallon tank..
Old Feb 4, 2008 | 06:15 AM
bad2006z71's Avatar
i have an 06 Z-71 with the flex fuel and it has a 26gal tank (ext cab model).
yes most every bolt on the fits a normal 5.3 will work with a 5.3 flex fuel. they are the exact same motor with a few modifications to the computer to recognize the ethanol and some upgrades to the fuel system because ethanol is more corrosive.
i have a k&n 63 series, 40 series flowmaster and a hypertech max energy. most programmers except for a special diablo predator do not recommend using ethanol fuel with them. other than that rock and roll.
Old Feb 4, 2008 | 09:08 AM
white06's Avatar
so the onlything i have to worry about is not using e-85 if i get a programer you are saying? there is only one in sandiego any ways
Old Feb 4, 2008 | 09:45 AM
bad2006z71's Avatar
yea the only company that makes a programmer for e-85 use is the Predator. i cant get it here in VA anyways so i dont worry about it.
what is your truck 4x4, ext/crew cab? what kind of mpg are you seeing right now
Old Feb 4, 2008 | 10:08 AM
white06's Avatar
it is 2wd, reg cab with a long bed. i am getting 22.3 on the highway i dont do much city driving
Old Feb 4, 2008 | 10:52 AM
jcbst12's Avatar
Hypertech makes a "Alternate Fuel" performance tune that can be used with crappy gas and E-85, BUT Predator has one too and it is much better.
Old Feb 4, 2008 | 12:12 PM
white06's Avatar
so would i be better getting one for the flex fuel or one just for a normal 5.3L. there in nowhere near me that sells the e-85
Old Feb 4, 2008 | 12:14 PM
jcbst12's Avatar
If you ever plan on running E-85, I'd do my homework. If not, just get a Predator and either uninstall the "custom tune" when you run E-85, or have someone make you a tune just for E-85, but then you will have to switch back aqnd forth from one tune to the other when you use 85 or 87
Old Feb 4, 2008 | 12:19 PM
white06's Avatar
THANKS FOR YOUR HELP. HAS ANYONE TRIED THE BULLY DOG POWER PACK THE TRIPLE PACK?
