Ford in a GM?
Old Mar 30, 2010 | 10:51 PM
lowtech.redneck's Avatar
Default Ford in a GM?
Can i put a Ford 350 engine into my 98 GM 1500? without swapping out the tranny or anything.. bolt up and go sorta deal
Old Mar 31, 2010 | 06:05 PM
gotstylez's Avatar
ford doesnt make a 350....they make a 351.... im sure the motor mounts are different... and the driveshaft will be different since it will be ford to a GM rear.. why the f would uw ant a ford anyway? too much work on the engines u gotta do...they put the dis, in the front...where do u think water goes when u go into a puddle? the front of the engine..horrible engines and design.. put a GM motor in it..it will all be the same..
Old Mar 31, 2010 | 07:12 PM
Turbo810's Avatar
No. You would have to change the trany as well.
Old Apr 1, 2010 | 04:11 AM
Worf's Avatar
No, you can't. Ford makes a 351 not a 350. The transmission will not be compatible either.
Old Apr 6, 2010 | 08:50 PM
jvp's Avatar
jvp
Member
If you need a new motor, shop the junk yards online you should be able to find a low mile
5.3 on the cheap!
vp
miltonluban
Aug 14, 2020 07:25 AM
hellozaizai
Mar 29, 2013 01:09 AM
SJTpackers
Jan 22, 2008 03:42 PM
colej11
Feb 20, 2007 06:30 PM
