fuel gauge problem
Old Apr 8, 2012 | 03:57 PM
941500LB's Avatar
Default fuel gauge problem
Hi I'm new this is my first post here. I just naught a 94 Chevy c1500 changed the fuel pump and everything was fine. About a day later I was driving and the gauge jumped from 1/4 tank to 1/2 tank and hasn't moved since. Not sure where to start on this any help is much appreciated thanks.
Old Apr 8, 2012 | 11:32 PM
Pickup Man's Avatar
My fuel gauge jumps all over the place, whenever it feels like it. I was told it was my sending unit, and since it's part of the fuel pump, and the fuel pump is in the tank, I have learned to live with it. I'm guessing you may have the same issue, or an issue with the gauge itself.
Old Apr 9, 2012 | 08:23 AM
Diesel Dan's Avatar
The two things that could cause this are the gauge itself and sending unit. If you had a broken wire or shorted wire the gauge would read either full or empty, not stick in the middle. The '94 model was still able to change just the pump and not the whole unit(module) correct? If so I also concur with Pickup Man that the sending unit is the most probable cause.
At least it is fairly easy to get the fuel pump out of those trucks, if you pull the box off.
rkramer
Oct 6, 2012 09:12 PM
00Silverado329
10
Sep 15, 2010 11:34 PM
alanjayne
Feb 12, 2008 04:44 AM
waytooevil
Oct 28, 2007 10:48 AM
mfarberg
Sep 7, 2005 02:03 AM
