Fuel pressure with 8.1L bucket?
Old Dec 9, 2007 | 11:27 AM
scot254's Avatar
Default Fuel pressure with 8.1L bucket?
Hi,
I just swappeda 8.1Lbucket and pump for a Silverado with my stock bucket on my GTO. Part # MU1417 GM #19133455.
I needed the extra capacity due to fuel demands on the modified GTO.
I wanted to see how the factory truck pump performed before swapping to a high flow Walbro 255.
After install the truck pump was putting out 53 PSI according to my gauge. Is this what they run at?
Appreciate the help,
Scott
Old Dec 9, 2007 | 07:37 PM
Cracker's Avatar
Default RE: Fuel pressure with 8.1L bucket?
Depends on the year but yes, that is normal operating pressure.
Old Dec 9, 2007 | 08:47 PM
scot254's Avatar
Thanks for the response. Do you know if this is just what the fuel pressure regulator limits it to? Or is the pump only capable of pushing out 53-55 PSI?
I need to be in the 60PSI range or retune it for a lower PSI.
Old Dec 10, 2007 | 12:29 AM
stopspazinout's Avatar
thats what the pump puts out at least on the 88-98 style it is. these newer designs dropped pressure down lower then that.
Old Dec 10, 2007 | 09:35 PM
Cracker's Avatar
60? Whatdid you do to the motor? Can you change the injectors to a lower requirement/higher output?
Old Dec 14, 2007 | 03:28 PM
scot254's Avatar
58-60 is factory PSI for an LS1. I would like bigger injectors and a retune, but injectors are around $400. A Walbro 255 which I have is only $100. I'm going to put that pump in and see if I can get the pressure back up. Thanks for the help.
macyt
Aug 1, 2009 07:14 AM
DennisT
Mar 24, 2009 09:59 AM
1985Chevy
19
Jun 20, 2008 09:42 AM
1985Chevy
34
May 31, 2008 12:18 AM
smcallis
Apr 6, 2008 02:33 PM
