Gear swap prices
Old Sep 19, 2007 | 09:55 AM
  #11
jcbst12's Avatar
Default RE: Gear swap prices
If I had a lift or even a garage or even a driveway I would, lol.
Old Sep 20, 2007 | 09:27 AM
  #12
BlackHorse99's Avatar
the only tough part is shimming it to get the gears to coincide right
Old Sep 20, 2007 | 04:48 PM
  #13
91CHEVYSILVERADO355's Avatar
It isnt that hard to do it itl take you maybe 4 hours for the posi and the gears both and you can get gears for around 200 dollars or so and the locker for about 400. pretty much the jist of it is rasie the diff pull the pan off pull the driveshaft off and make sure to mark it on the shaft and the pumpkin then remove the pinion nut and count how many turns it takes to get it ouf so you have the same pinion depth then unbolt the carrier and keep the shims on both sides of it stright cus they are side specific sometimes and different sizes then take off the ring gear and install the posi then slap it back together and you good to go.. just a rough explainaiton though .... its about a 4 beer job...lol
Old Sep 20, 2007 | 06:42 PM
  #14
hunt4game29's Avatar
So 91chevysilverado355 since you know how does that mean you are willing to help How about the front is it hard to do also? And i dont have to do a locker do I?
Old Sep 20, 2007 | 10:04 PM
  #15
i havent done the fornt, but i did do my rear like 6 times in the last 2 months
Old Sep 21, 2007 | 01:57 AM
  #16
stopspazinout's Avatar
geeeze man what geas are you running down there?
Old Sep 21, 2007 | 07:20 AM
  #17
jcbst12's Avatar
I've helped in doing a locker and a limited in a Toyota. (I know I know but it had a chevy 350 in it!) We did a locker in the rear and a limited slip in the front. From what I understand that is the way to go as the limited slip will allow enough 'give' in the driveline to prevent binding.
Old Sep 22, 2007 | 07:17 AM
  #18
smoke20's Avatar
blackhorse - why in the world have you had to change gears in the rear axle 6 times in 2 months? Were you just trying different ratios?
Old Sep 22, 2007 | 08:30 AM
  #19
Argon's Avatar
I would not reccomend doing it yourself without some real knowledge/tools..
If your skilled in measuring backlash and shims,and have a good manual..go for it though
Old Sep 23, 2007 | 10:56 AM
  #20
argon pretty much nailed it, i need to get someone to adjust the backlash for me
