Getting rid of ABS...
Old Feb 18, 2009 | 10:24 PM
98Silverado4Ever's Avatar
Default Getting rid of ABS...
Idk if anyone else has the same problem as me when it comes to my ABS kicking on every time I come to a stop, but are there any ways to disable the ABS and still have normal brakes??..just wondering.
Old Feb 19, 2009 | 07:10 AM
chrisbmo2000's Avatar
yep pull the abs fuse..........or you could clean your sensors and exciter rings which may help solve the problem you are having are you sure its the abs and not warpped rotors? they would feel the same
Old Feb 19, 2009 | 08:36 AM
bfg112's Avatar
There was a regional recall on the abs. The salt on the roads was corroding the sensors. Try cleaning as chris said, but also call your local dealer to see if the recall applies to you.
Old Feb 20, 2009 | 04:30 PM
Where is the ABS fuse located?? And I called my dealer and they told me my truck was not listed in the recall.
Old Feb 20, 2009 | 05:16 PM
gpet6669's Avatar
The fuse is in the main fuse panel under the hood on the driver side. I had the same problem with my 98 and I had a bad hub. Now that I think about it I think my other hub is on it's way out, even though it is not doing the false ABS engagments.
Check your front hubs and see if they need to be replaced.
-Chrisbmo2000, warped rotors will not be the same feeling due to the ABS pump coming on when brakes are applied and only doing it at certain points. Warped rotors you would feel all the time and wouldn't be hit and miss. Nor would you hear the ABS pump come on and the feel of the peddle is totally different when the rotors are warped vs the ABS pump pumping the brakes.
I used to live in ND and it gets really icey there, in fact I drove on nothing but ice for a month straight. I know what the ABS pump feels like in a multitude of vehicles. It was so cold there the grave roads were iced over and forget about the mud. That is a FROZEN HELL HOLE! Literally.
GMCSierraFan
Apr 25, 2011 04:38 PM
knoxy
8
Feb 16, 2008 02:09 PM
silverado_ia
May 21, 2007 10:09 PM
makoltd
Jan 7, 2007 12:13 AM
JSMConstruction
May 22, 2004 07:54 PM
