Giving me fits
I have a 1993 gmc short bed 4.3 v6 5 speed. I have change plugs wires cap rotor coil pack battery fuel filter. Truck runs good till it gets hot. Then it starts sputtering and looses power and runs bad. I am completly lost any suggestions would greatly appreciated. Thanks a lot.
Try the ignition control module. Both Chevy and Ford have had issues with them for years.
check your o2 sensor or sensors
i changed mine on my 94 and wow what a differance it made |
Thanks appreciate it.
I changed the 02 no luck. Thinking about throttle positioning sensor and wire for my next trick.
Originally Posted by dozer327
(Post 69454)
also check you egr valve and pcv valve and map sensor |
Sounds like a typical coolant temp sensor going bad. It's the one by the thermostat.
