Giving me fits
Old Jul 16, 2011 | 09:52 AM
dozer327's Avatar
Default Giving me fits
I have a 1993 gmc short bed 4.3 v6 5 speed. I have change plugs wires cap rotor coil pack battery fuel filter. Truck runs good till it gets hot. Then it starts sputtering and looses power and runs bad. I am completly lost any suggestions would greatly appreciated. Thanks a lot.
Old Jul 16, 2011 | 09:57 AM
MrDragon's Avatar
Try the ignition control module. Both Chevy and Ford have had issues with them for years.
Old Jul 16, 2011 | 03:23 PM
cubpak89's Avatar
check your o2 sensor or sensors
i changed mine on my 94 and wow what a differance it made
Old Jul 16, 2011 | 03:26 PM
dozer327's Avatar
Thanks appreciate it.
Old Jul 16, 2011 | 03:28 PM
dozer327's Avatar
I changed the 02 no luck. Thinking about throttle positioning sensor and wire for my next trick.
Old Jul 16, 2011 | 03:33 PM
cubpak89's Avatar
have you looked for vacum lines leaking to do that spray some wd40 or whatever on the line around the fittings while running if it spits and sputters then the vacum line is bad do them one at a time
also check you egr valve and pcv valve and map sensor
Old Jul 16, 2011 | 03:48 PM
Sounds like a typical coolant temp sensor going bad. It's the one by the thermostat.
hp81
Silverado/Sierra FAQs
Feb 21, 2013 06:21 PM
PostRelease
Apr 1, 2010 07:00 AM
samwise2158
Mar 24, 2009 11:12 PM
J0kersG0tcha
Jan 5, 2007 02:02 AM
