GMC no air coming from vetns
Old Jul 24, 2014 | 06:36 PM
cswolley's Avatar
Default GMC no air coming from vetns
Hello, I have a 2006 gmc 1500 with automatic temp control. Four months or so ago I replaced the resistor. Everything worked good. Last week I had no air coming from my vents.
I checked the power to the resistor and the blower motor.
The 40 amp fuse is good.
I checked the blower motor all is good.
Old Jul 24, 2014 | 06:43 PM
NullHead's Avatar
So the question is, does the blower spin? Spin slowly? If your blower gets power and ground, and the fan still doesn't spin, then your blower is bad.
Old Jul 24, 2014 | 07:01 PM
cswolley's Avatar
The blower motor spins fast
Old Jul 25, 2014 | 07:39 AM
NullHead's Avatar
So you're having a problem with the air coming from your dash vents? Will the system switch to the floor vents or defrost? If you can, use a tech2 or maybe even a snapon scanner might do it, see if you can get in and read the codes in the HVAC control module. I'd guess it's probably a mode control valve actuator if the modes don't switch. Just a guess though, it would be helpful to know if there's any codes stored in the HVAC module though.
DPD3000
11
Dec 13, 2012 06:29 AM
WALT258
Jan 21, 2009 07:07 PM
aDcAT 13
Jan 12, 2008 08:56 PM
aDcAT 13
Oct 1, 2006 05:25 PM
aDcAT 13
Sep 28, 2006 09:53 PM
