Hard Start After Engine's Warm!!??
Old Jan 31, 2011 | 08:24 AM
Bmsmith82's Avatar
Default Hard Start After Engine's Warm!!??
I have a 2001 Chevy 5.3 with 172,000 on it. Only ONE problem with it, truck fires up easily when cold but when i stop for short amounts of time after the engine's warm, i have to crank the engine usually twice and it fires up. Or I can cycle the pump a few times and it fires up. It smells a litte rich when it fires likewise.
To throw a hitch into my problem, when the engines warm and it sits for a couple of hours, it usually fires up with no issues.
I changed my plugs and plug wires at 160,000.... I change my fuel filter every 20,000.... I run Lucas injector cleaner every other month or so...
My FPR doesn't leak when the pressure hose is pulled off....
My Gas Gauge is doing the notorious empty to full thing....
If you know what this may be, I will sit here and listen!
Thanks,
Brad
Old Jan 31, 2011 | 12:44 PM
chrisbmo2000's Avatar
sounds like the pump is bleeding off pressure may be time for a new one....but I would replace the FPR first even though its not leaking
jdgolightly
May 24, 2011 02:53 PM
Themajickman
Nov 26, 2009 10:21 AM
z50kidd
Oct 11, 2009 12:53 AM
00serria
Dec 2, 2007 01:57 PM
rmriderz
Mar 9, 2006 06:28 PM
