help please: son w/'97 5.7 Vortek, int. power loss
Old Feb 10, 2008 | 06:40 PM
  #11
smoke20's Avatar
Default RE: help please: son w/'97 5.7 Vortek, int. power loss
Start simple with the fuel filter, look at the connections to the fuel pump as well and see if they are corroded and making poor contact. Next run some injector cleaner through.
Old Feb 12, 2008 | 01:35 PM
  #12
DennisT's Avatar
Thanks, Smoke, and All. Last report is he's delayed leaving the Coast so he can work on his truck. Even I had forgotten those things had the fuel filter on the frame rail. He did not know at all and is changing it. He DID say he had changed the fuel pump within the last year. So I think we're headed to injectors if the filter doesn't do it.
Those also had another fuel filter under the hood didn't they?
I'll update when he gets over here, and we'll hear from time-to-time as this unfolds anyway.
Dennis
Old Feb 12, 2008 | 01:51 PM
  #13
Argon's Avatar
INJECTORS WOULD CAUSE A MISS,NOT A SUDDEN POWER REDUCTION
Old Feb 12, 2008 | 02:32 PM
  #14
jcbst12's Avatar
I second, (or third or fourth) the fuel filter and pump idea. If you never changed the fuel filter, do it anyway. Then check the fuel pressure.
Old Mar 25, 2008 | 12:37 AM
  #15
DennisT's Avatar
Default RE: help please: son w/'97. power loss: Solved
I promissed an answer when this trouble was resolved. It took weeks to get everyone together over the intervening 300 miles.
I's fixed.
Problems: Several bad contacts/components inside the steering column. That cleaned up all check engine lights and other failed components.
Lastly, poor running was a....get this....cracked block.
One replacement wrecking yard engine and he is finally on the road.
Thanks to everyone, Dennis
rbiz
Jul 24, 2012 07:12 AM
Extacie
Jun 7, 2009 01:37 AM
Carbuff71
Apr 24, 2008 07:50 PM
Argon
20
Apr 9, 2008 11:51 AM
