How big of a tire can I fit?
Old Dec 18, 2008 | 06:22 PM
  #11
USARMYWHEELER's Avatar
Default RE: How big of a tire can I fit?
Moose, R you still running stock rims on your rig, i am looking to do the same to my 08 Z71 with a Buck Stop front winch bumper
Old Dec 18, 2008 | 10:46 PM
  #12
Rockstar112's Avatar
I think you can only fit a 285 but I aint too sure about the newer ones.
Old Dec 19, 2008 | 07:00 AM
  #13
moose's Avatar
Yes, I still have my Chevy stock wheels. My 2008 Silverado came with 265-65-18s. I needed the leveling kit to move up to 285s. 305-50-20s were an option, but the 20s were way too expensive for me at the time and believe it or not I'd gain width, but lose an inch or so in height with the 20s.
Old Dec 19, 2008 | 09:39 PM
  #14
TheMan21's Avatar
I have Motto MT700 18" Chrome wheels wrapped with LT 325/60R18 Nitto Terra Grapplers (33") on my '07 Silverado with a 6" lift and they still rub a little bit, only when making a sharp turn. I would have had to do some wheel well shaving to fit the 35s that I wanted.. My dad wasn't for shaving the wheel well... Hope this helps...
[IMG]local://upfiles/7521/624964EF9DF74DE1826BF8DB5445822D.jpg[/IMG]
Old Dec 19, 2008 | 09:42 PM
  #15
redgp's Avatar
I kept on researching and i came across a thread on gmtrucks.com that has the same topic. The 305/55/20 will fit with a 2" leveling kit and the stock 20" rims. The rims cant be too wide otherwise it wont fit.The tires look really nice with that size. Thanks for the info and input guys. when i get everything together ill post some pics up to show you guys.
Old Dec 19, 2008 | 11:11 PM
  #16
redgp's Avatar
My stock tires are 275/70/17. I looked at the wheel and it has plenty of room. my local 4 wheel drive shop told me today that i can only fit 285/50/20. In that case it's not even worth going through all this trouble. There is a guy on chevytruckworld.com that is running 305/50/20 with a leveling kit. He said the 305/55/20will probably rub a lot. Another guy is running the 305/55/20 in a gm forum with a 2" lift kit. Now i ran into another problem. The rim that i likehas to be9" or less i found it with 8.5 but i dont know if itll fit because it has a+10 offset. I dont know if its abig difference over the factory and that in fact will make my tires rub. Any clues on this new topic?
Old Dec 22, 2008 | 03:02 PM
  #17
bfg112's Avatar
In my opinion it's absolutely worth it if you want to go from a 17 inch rim to a 20 inch rim. As far as the offset goes, I'm not sure what the factory offset and backspacing are. The backspacing will have a greater effect on wether or not you will have rubbing. You don't want the tire to rub on the frame rail, as the frame rail is not movable. If you end up rubbing on the fender side, most of the time you can get away with only trimming the plastic shroud under the front bumper.
That said, if you do rub the frame rail you can use a spacer to move the wheel out, then you could trim the plastic shroud if you need to. Unless you find someone with the exact same setup you want to run you're pretty much going to have to dive in and see how deep the water is.
Old Aug 13, 2021 | 06:09 AM
  #18
Robertcladner's Avatar
Originally Posted by redgp
I just got my wife a 08 silverado 4X4. Im planning on just leveling out the front and putting some mud grapplers on 20" rims. Im just new to all of this because its her truck im just into fast cars. Point is I dont know how big of a tire i can fit without lifting it too much. I keep hearing this magic number of 33" tires. So I dontknow how the tire dimension would have to be.If i just go with a 33" will that basically just work out the dimensions to total out a33" tire? Will this rub? This is the tire that she liked. Will a set up like this work for me without problems? thanks in advancefor your help.
cgi.ebay.com/ebaymotors/20-XD-775-ROCKSTAR-RIM-AND-TIRE-NITTO-MUD-GRAPPLER-33_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q 7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a 1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem2 60331025726QQitemZ260331025726QQptZMotorsQ5fCarQ5f TruckQ5fPartsQ5fAccessories
Use tire calculator - https://tonybassogm.com/wheels-tires...ze-calculator/ to compare tire sizes based on tire diameter, radius, sidewall height, circumference, revs per mile and speedometer difference.
Old Aug 27, 2021 | 06:07 AM
  #19
rudrasingh's Avatar
Consult with tyre mechanical. They will help you.
Nightfox
Nov 22, 2015 06:14 PM
bbll120
Jan 27, 2011 11:38 AM
halbesma
18
Sep 8, 2010 10:44 PM
Bumrush
15
Feb 5, 2009 12:14 AM
donth8
14
Aug 24, 2007 10:55 PM
