how to get more gas mileage
Old Oct 7, 2008 | 10:26 PM
Steven's Avatar
Default how to get more gas mileage
i got a 1994 Chevy Silverado 2500 with the 350 and i wanted to know is there any way to get more gas mileage without spending a bunch i already got a k&n air filter i also cut the cat off and im getting a flowmaster 50 series soon any other sugestions
Old Oct 8, 2008 | 07:49 AM
jcbst12's Avatar
Default RE: how to get more gas mileage
A custom tune or a Predator programmer, keep the tires inflated and keep up with the regular maintenance and tune ups. Thats about it man. Make sure you replced the fuel filter, trans filter, plugs, wires, etc... when they are due to be changed.
Old Oct 8, 2008 | 09:32 AM
gpet6669's Avatar
Also try and avoid stop and go traffic, the less you slow down the better. But the faster you go the worse it is, if you have to leave 15 mins early to drive 10 MPH less on your way to work then it may be worth it for you. When you do get stopped, roll into the throttle slowly!!!! Your truck should be getting best fuel mileage at about 52-58MPH. Stay between that if at all possible for the best fuel econ. Other than that, there aren't really any other tricks that havent been mentioned already on this thread. If you want more tips and tricks to increase your fuel econ and not spend a whole bunch of money, look up the Ultimate Free Mods list in this forum. Then search other threads about the same subject that you have just asked about. I have a whole list in here about this same subject. Good luck and keep your foot out of it!
Old Oct 8, 2008 | 10:39 AM
bad2006z71's Avatar
94=TBI, no programmers for tbi, could get a tune from like tbichips.com or something like that.
Old Oct 8, 2008 | 11:20 AM
Argon's Avatar
keep your foot out of it...service as mentioned...but 15'ish is about all that tbi is gonna get
Old Oct 8, 2008 | 01:44 PM
adampgasser's Avatar
Member
The best tip I found was slowing down on the interstate I used to drive 73 on the insterstate and would always get 14 with my 1998 k1500 with the 350, now I keep it at about 67 mph and my last trip back home I hit 18 mpg with about 1,000 pounds of tools in the back with my mud tires on. Easy accelerations and coasting when you can make a big difference also.
Old Oct 9, 2008 | 08:10 AM
jcbst12's Avatar
You need more torque from the engine. Consider a 180 degree stat, TBIchips PROM and a spiral throttle body spacer. That will help, especially your highway MPG. Put a high flow CAT on if you can. I removed my CAT on my 91 and didn't get very good city MPG.
Old Oct 9, 2008 | 01:53 PM
timber74wolf's Avatar
under drive pulleys, shorty headers and a fabricated ram air setup.
Old Oct 10, 2008 | 12:45 AM
HarderThanRocks's Avatar
Car pool...
Old Oct 10, 2008 | 02:55 AM
karl's Avatar
Keeping the tires filled up to their max pressure is a practical and easy way to have a better gas mileage.
