humming noise in front end
Hows it going guys. Quick question. I have a kind off a humming noise coming from my front end. I just had my front driverside bearings changed. The bad bearing made my tire wear uneven. Would this sound be because of that. It sounds like a worped tire when I slow down so does the sound when I speed up it does as well. Any ideas on what it is. Had the truck One year bought used with 59,000 km and already did FDS bearing hub, got a leak in my tranfer case what else am I in for.
You can try and rotate the tires see if the sound follows. This would eliminate a tire issue. You should have replaced both front wheel bearings, anytime you do maintenance like this it is best to go ahead and do both sides.
