I can't get the clunking to go away!!!
My intermediate shaft will not stop clunking. I've greased it 2x in the past month and nothing changes. I've shoved a ton of synthetic wheel bearing grease in the bottom of the shaft and worked it in and out hoping that the grease would make the clunking stop. Well...it hasn't. What do I do to make this stop??? Suggestions???
RE: I can't get the clunking to go away!!!
i will never stop clunking thats y gm had a huge recall on them
there is no recall on them..
gm does have a new shaft that is greaseless and cures the problem. However,,,don't be fooled...some people are assuming its the shaft when ANYTHING clunks...but there are many other clunkable componets |
i just bumped an old thread on this problem titled (i'm new here and need some help)
ORIGINAL: Argon there is no recall on them.. gm does have a new shaft that is greaseless and cures the problem. However,,,don't be fooled...some people are assuming its the shaft when ANYTHING clunks...but there are many other clunkable componets I'm thinking the wheelbearing grease is too thick to get up along the shaft, what other grease should I get? |
no need for grease...take it apart under the hood and stroke it about 15 times and bolt er back up..oh,you'll be amazed
I stopped by the Chevy dealership yesterday to look into getting a revised shaft and the Service Manager said that Chevy just came out with their 10th revised shaft (part # ends in J). He suggested to try greasing it up againbecause he doesn't have faith that this new revision will work. Now that's confidence in the engineers at Chevy.
The new shaft is the cure...someone here posted the part #..it ends in 14...its greaseless
