i know i know not a silvy...
Old Oct 21, 2007 | 12:46 AM
stopspazinout's Avatar
Default i know i know not a silvy...
friend of mine has a 97 saturn and its having a real hard time starting now, before it used to sometimes sputter while accelerating. now it wont start yet i can still hear the fuel pump running after replacing the pump relay. any ideas hear radther not go for the pump unless im absolutely sure.
Old Oct 21, 2007 | 12:57 AM
racethisz71's Avatar
Default RE: i know i know not a silvy...
check the fuel pressure
Old Oct 21, 2007 | 12:59 AM
even eaiser way spray a little throttle body cleaner in the thottle body if that doesnt start it, its not a fuel problem
Old Oct 21, 2007 | 01:22 AM
tried starter fluid in the throttle body that used to get it to start but not anymore after changing the fuel filter. the throttle body does look quite dirty internally.
Old Oct 21, 2007 | 09:10 AM
it will run on starting fliud if it doesnt it would try lookin for spark
Old Oct 21, 2007 | 09:15 AM
72charger's Avatar
I'd check the ignition module and coil packs out if it's not a fuel problem. Might check and make sure the spark plugs aren't fouled out but that would make it only run sluggish some of the time. That'd be a constant problem I think.
Old Oct 21, 2007 | 09:44 AM
seb37's Avatar
what motor is in that Saturn?
Old Oct 21, 2007 | 11:18 PM
like a .8 or 1.9l dohc. tried new coil packs new module and plugs and wires made it run better while working now it wont start.
Old Oct 22, 2007 | 07:08 AM
72charger's Avatar
Ah heck, just tell him he needs a truck.
Old Oct 22, 2007 | 10:11 AM
seb37's Avatar
Crank Sensor?
