I think i have a problem with my Fuel pump?
Old Jan 20, 2011 | 08:05 PM
guinell1's Avatar
Member
Default I think i have a problem with my Fuel pump?
So i have a 2000 silverado 1500 with the 5.3, i think the fuel pump might be messed up? well heres how it goes. before i started having problems i noticed that when the truck is cold, and i turn on the ignition (not starting it) i got a pretty loud kinda like something was vibrating against sheet metal coming from around the gas tank. i took note of it but nothing really changed with the truck it fired right up no problems. now i seem to have another problem. when i turn it on and try to start it it wont start, takes a couple times cranking to start it. is my fuel pump gonna die on me? and i forgot to mention it only happens after the truck has been warmed up and i go to like a store or something and come back out. when she's cold it still fires right up. seems really weird.
Old Jan 20, 2011 | 08:08 PM
guinell1's Avatar
Member
ive also replaced the fuel filter no changes
Old Jan 20, 2011 | 09:29 PM
RUFFNECK4LYFE's Avatar
Need to hook up a pressure tester on it to find out psi to make sure it is your pump. Im pretty sure it is, just need to make sure.
Old Jan 20, 2011 | 10:10 PM
guinell1's Avatar
Member
yea i wouldnt wana buy a new pump and that not be the problem..
Old Jan 20, 2011 | 10:13 PM
You could look at one of your plugs and O2 sensors to see if it running lean.
Old Jan 27, 2011 | 11:45 AM
RGHnRDY CHEVY's Avatar
How do you go about doing this pressure test? Where can you find a tester? Im guessing you hook it on the fuel line before the filter?
Old Jan 27, 2011 | 11:57 AM
You should have a pressure test point under the hood on the fuel line. Screw on a gauge and see what you got. Be careful when you first screw it on, you want to relieve the pressure or do like most and just wrap a rag around it so the gas won't squirt you.
Old Feb 8, 2011 | 09:29 PM
guinell1's Avatar
Member
where can i buy a pressure tester kit?
Old Feb 9, 2011 | 07:51 AM
Worf's Avatar
At any autoparts store
NullHead
12
Feb 1, 2012 11:44 PM
Razoo
9
Nov 15, 2011 07:27 AM
Wiked
Jun 29, 2011 06:11 PM
ecarri100
Jan 9, 2011 09:54 AM
chrisbmo2000
Dec 24, 2010 03:35 PM
