idling problems
got my truck running and its having trouble idling right now. i re adjusted the timing and got it to idle on its own. after trying to drive it it idles rough and has to have a little gas to stay running. any ideas on what else to check on?
RE: idling problems
no codes?./.what was done to the truck?..it runs ok on the road?
RE: idling problems
motor change. it can drive. but its not running well.... messing with the timing helped it some. but it still acts like a spark problem.
RE: idling problems
2 THINGS CUM TO MIND...
check the egr...a hung open egr (or mis-installed gasket) will not idle. grounds...grounds at the thermostat housing..these grounds CAN NOT share 1 bolt..seperate them...1 on the thermo housing,1 on the intake |
RE: idling problems
that could be a problem then cause there are 2 grounds at thermostat one on either bolt hole thought something looked wrong and ill look into the egr to.
RE: idling problems
Check the vacuum lines. I had that problem with my 82 c-10. Egr valve is also a good place to look.
RE: idling problems
whu happened??
RE: idling problems
well i took it to a shop to get looked at and inspected and theyre telling me the distributor is worn out and the pickuo coil keeps touching causing it to die every revolution at idle.
RE: idling problems
very possible...reman dist's are purty cheap
RE: idling problems
thats whats about to go in. im about to be back on the road again :D
