Ignition problems ?
Old Mar 18, 2010 | 08:15 PM
56 panhead's Avatar
Default Ignition problems ?
I have a 92 sierra,4.3, new coil,plugs,wires,cap,rotor,and ignition module in the dist. Rebuilt the tbi, It starts fine,surges a little at idle, put it in gear and move and it cuts out,misses,and acts like its running out of fuel,fuel pressure is fine,when I hooked up a timing light my timing marks were VERY erratic, jumping all over.any ideas or sugestions? thank you
Old Mar 21, 2010 | 05:55 PM
RUFFNECK4LYFE's Avatar
Check for vacum leak. Use starting fluid and spray in short bursts around the whole intake and see if the idle goes up when you do.
Old Mar 25, 2010 | 06:54 PM
56 panhead's Avatar
Default back again
checked for vacume leaks, all ok there, checked fuel presure again and noticed it was dropping, pulled the tank and the hose between the pump and tube had split while I'm there I'm putting in a new pump and strainer also, thanks for the help so far, sure I'll be back!
chevy1224
Jun 17, 2010 10:36 AM
demobud
Jul 7, 2008 05:37 PM
Chestah
Oct 28, 2006 03:53 PM
bosco269
Aug 16, 2006 11:30 PM
jack95
Jul 3, 2006 01:55 AM
