interior lights/cargo light not working
Old Mar 9, 2008 | 04:36 PM
  #11
Argon's Avatar
Default RE: interior lights/cargo light not working
a test lite...make sure the fuse has power on both sides...an up-to-date aftermarket shop could help ya
Old Mar 9, 2008 | 11:35 PM
  #12
chevy112488's Avatar
ok so its popping a fuse every time i turn the light on. o'reilly said there's probably a short somewhere... i dont know... i guess ill just take it to a shop
Old Mar 10, 2008 | 05:30 AM
  #13
Argon's Avatar
probably your cigg liter if its popping it that fast...do you have some aftermarket lighter in the hole?
Old Mar 11, 2008 | 10:56 AM
  #14
nope, just the stock cig lighter and a phone charger
Old Nov 23, 2008 | 02:15 PM
  #15
oaker 77's Avatar
I just finished finding the cause of the same problem, and joined the forum so I could post a reply. I have a 2002 Silverado andI had a problem with thewireing harness plug that goes into the relay panel just to the left of the brake pedal. If you remove the cover of the relay panel and wiggle the wires in the big connection plug, you will likely find that your interior lights will flicker. Hope this helps someone.
Old Feb 7, 2009 | 02:57 AM
  #16
crazydrive's Avatar
Thanks for the post oaker77. I'm currently having this problem with my vehicle and I'm just glad to finally have found a solution for it. It helped me a lot. Now its fixed.
_________________
WTB: spyder headlight
Old Mar 14, 2009 | 10:00 PM
  #17
earlray25's Avatar
My truck is doing the same thing, however it is very intermittent. Sometimes it works and you can hear the relay click when it comes on or off. Even if your driving down the road. I did notice that when the interior lights/ cargo lights do not work, the horn also does not work when you hit the lock button twice on the remote. I have wiggled and checked all the wires behind the relays and it still has the same problem. could it be in the keyless entry system?
Old Mar 14, 2009 | 10:01 PM
  #18
earlray25's Avatar
Horn doesn't beep with the remote when the lights aren't working
Old Mar 15, 2009 | 12:30 AM
  #19
gixxer32404's Avatar
loose ground????
Old Mar 15, 2009 | 09:43 AM
  #20
20''strong's Avatar
Member
Thanks for the input oaker 77,just pushed in the harness plug and fixed my interior lights.they were working off and on, thought i had a short so i pulled the fuse cause i didnt really want to trace the wires.must be a 02 thang.
