just a quick question
Old Dec 26, 2007 | 08:45 PM
BigRandy95's Avatar
Default just a quick question
if i put a throttle body spacer on my 97 350 5.7 will i have to adjust my cruise or my throttle control? just wondering and if i do is that hard?
Old Dec 26, 2007 | 09:44 PM
racethisz71's Avatar
Default RE: just a quick question
on my 00 they gave me relocator brackets and it wasnt hard to adjust at all
Old Dec 27, 2007 | 12:48 AM
chevy112488's Avatar
on mine it came with a bracket to move them to the proper position. all you did was undo two screws, put the bracket on, and put the screws back on. very simple. once i figured out what to do. the instructions sucked. but overall its pretty easy.
Old Dec 27, 2007 | 03:25 AM
MASSIVE_911's Avatar
YOU KNOW WHAT, I HAVE A 1997 GMC SIERRA 5.7 AND THE ONLY PROBLEM I HAD WAS WITH THE K&N. K&N DOESN'T WORK WITH A TBS I HAD TO MAKE A SPECIAL MODIFICATION TO MAKE IT WORK. AS FOR THE TWO CABLES, I DIDNT MAKE ANY ADJUSTMENTS, YES THEY DO LIKE YOU NEED A BRACKET TO ADJUST THEM, BUT MINE DIDNT COME WITH IT SO I JUST BENT THE BRACKET IT HAS TO MAKE IT FIT AND I HAVEN'T HAD A PROBLEM WITH IT SINCE I PUT IT ON. IF YOU HAVE A K&N INTAKE, GOOD LUCK MAN, I HAD TO TAKE OFF THE HEAT SHEILD JUST TO MAKE IT FIT, AND WHEN YOU CLOSE THE HOOD, THE TOP OF THE INTAKE HITS IT. BUT IT DOSE SOUND NICE AFTER YOU PUT IT ON, IT HAD A DEEPER SOUND AND MAKES A WHISTLE NOISE WHEN YOU STEP ON THE GAS
Old Dec 27, 2007 | 02:39 PM
Cracker's Avatar
Massive - there's no need to yell, we're all in the same room.
Old Dec 27, 2007 | 07:25 PM
stopspazinout's Avatar
mine didnt come with a relocator so i grabed some larger bolts and used washers to space the bracket.
Old Dec 28, 2007 | 06:54 PM
BigRandy95's Avatar
ok thanks for the replys. sorry it took so long i was away from a computer for a few days. But my next question is where can i get a good one for cheap? i would immagine there is not much of a difference in all of them except for smooth and grooved.
Old Dec 28, 2007 | 07:28 PM
Chevycowboy's Avatar
I got mine at "JCWHITNEY.COM". There, I think it was just a little over 100$, go with the Airaid. But dont be suprised if you dont nottice any change but a slight whistle noise. I have the 01' Silverado and thats all the 100$ got me. . Good Luck!
Old Dec 29, 2007 | 08:26 AM
popo's Avatar
cruise control must be nice.
Old Dec 29, 2007 | 05:33 PM
smoke20's Avatar
You can get a transdapt from Summit racing for $52.
