Leveling the front
Old Mar 12, 2008 | 07:34 AM
legacy's Avatar
Default Leveling the front
Since i have a 4x4 z71, i can just turn the keys in the front of my truck and get like another inch or so out of it so its level, but i dont know where these keys are or how to turn them so any help will be appreciated.
Old Mar 12, 2008 | 10:09 AM
rjdoolay's Avatar
Default RE: Leveling the front
I just had a local tire shop turn mine. That way i could get it alligned at the same time. Just to make sure my tires wouldnt ware funny.
Old Mar 12, 2008 | 10:29 AM
moose's Avatar
Today, I pick up my 2008 silverado that has had a leveling kit and duals installed yesterday. I don't have torsion keys. I have a coil over shock assembly. I think all 5.3L 2008s are this way.
Old Mar 12, 2008 | 10:35 AM
gpet6669's Avatar
The keys are under the cab about 6' behind the front bumper. You will see the torsion bars going into them. There will be a cross member there and then there should be some bolts facing straight down. Turn them equal amounts each tightening them both. Make sure that you measure the vehicle hieght and figure out how much you want to turn them, one piece of advice make sure that you are on the most level ground that you can. When you get ready to measure after the adjustments make sure that you drive the truck a bit so that the vehicle is at a natural rest when you measure. Turn them some and then measure. Once you are all done getting it to the height that you want, go and get it alligned. Good luck and make sure to lube the bolts and let it penetrate for a bit before you try and turn them.
6mins2live's Avatar
rjdoolay
How much did it cost ya to do that?
Old Mar 12, 2008 | 12:39 PM
rjdoolay's Avatar
It was about 75 bucks so not to bad.
Old Mar 12, 2008 | 04:34 PM
6mins2live's Avatar
Yeah thats not bad at all. NowI am seriously considering it. I was going to just go with a body lift but it sounds like this is better and cheaper. Does anyone know if this lowers your loadingor towing cap?
Old Mar 12, 2008 | 05:55 PM
gpet6669's Avatar
Changes nothing but the ride height and the ride quality.
Old Mar 13, 2008 | 06:01 AM
legacy's Avatar
Ok i found the torsion bar and the bolts facing down in them, do i just gotta tighten them by hand?
Old Mar 13, 2008 | 09:22 AM
gpet6669's Avatar
Yeh I would tighten themwith a ratchet and socket, mainly becouse then you can adjust them a little more
precisely. Make sure that you measure then turn and measure then turn some more. Then get it alligned after all is done.
