Location of ECU on 88' GMC Sierra 1500
Hi,
New on here and hoping you guys can supplement what I have taught myself and the Chilton. I had bought a used alternator (which ended up being wrong alt) I put it in then I forgot that my battery had full charge from maintenance charger and my helper hooked a booster to it, so when I cranked it, I'm sure most of you probably know what occurred. A great big puff of smoke and then nothing. I believe it's called positive wire from battery got smoked. So I was looking at other wires to see if anything else needed replacing, and there is a little black box on firewall, drivers side. When I opened it, it looked a little 'corroded?' . The helper took that off and now I can not find it. So I bought a splice kit for wire that burned ...... Any pointers on that would be great AND is that box the ECU ? And how difficult is it to remove/replace. Any pointers, I would be eternally grateful Thanks |
