Lowering rear
Old Sep 24, 2013 | 05:29 PM
poncho62's Avatar
Default Lowering rear
I need to lower the rear end of my 97 GMC a couple of inches to level out my 5th wheel trailer when towing it. The previous owner put in heavier springs (6 leaves) which I like when having the extra weight of the trailer on, but it makes the rear sit up a bit. The trailer sits a bit up in the front.
I see these lowering shackles on eBay etc to lower the rear....anyone used these?....Pros/Cons?
Fully Adjustable 2" OR 1" DROP AVAILABLE
Installation time: .5 hr/wheel
Our Shackles are Powder coated to fight corrosion and provide long life. Parts are CNC stamped out from P&O high grade steel. Fixtured and tig welded for perfect bolt on fitment to your truck. Bushings are high quality rubber poured from very high durometer materials for long lasting performance
Old Sep 24, 2013 | 07:54 PM
I would say that's the way to go to maintain the same ride you already have.
When I saw the .5 hr per side I almost laughed out loud
I don't think your 97 is going to give up the original shackles that easily.
It may even involve replacing the shackle bolts after you burn the originals off
horsensracing
Sep 25, 2006 05:38 AM
S10boy
Jul 25, 2006 02:24 AM
kuntrysilv
Jul 2, 2006 01:44 AM
dodgeram1998
May 1, 2006 02:34 AM
zeke
Aug 14, 2005 02:37 PM
