MAF
Old May 9, 2007 | 09:56 PM
smoke20's Avatar
Default MAF
Does anybody know if the aftermarket MAF sensors can read higher airflow than stock? for example (and these are random numbers) if the stock sensor can read 0-800 CFM, is this the same for the aftermarket? Or can the aftermarket read say 0-1000 CFM? This will make a big difference in performance as the computer will not adjust far enough without the correct info.
Old May 9, 2007 | 10:05 PM
MrLM7's Avatar
Default RE: MAF
I've been looking around for custom tunes and all the tuners say not to change the MAF, because it will cause a performance loss when you get a tune. They say it's hard to make it match up, data wise, as the aftermarket MAFs give a different signal... Just a thought. I know you want to do the heads and cam swap.
jluevanos74
8
Jun 19, 2007 09:25 AM
chevyrules
8
Jun 13, 2007 07:38 PM
ShawTownSpecial939
Jun 4, 2007 06:49 PM
hunt4game29
19
May 9, 2007 11:18 AM
gm trucker
Mar 13, 2007 12:18 AM
