descreened MAF
Old Jun 16, 2007 | 01:45 AM
jluevanos74's Avatar
Default descreened MAF
Whats up guys Im new to this site but I read on many trucks it said descreened MAF. I was wondering what that was? I have a 06 Z71 MSD wires, E3 plugs, K&N intake, superchips tuner, throtle spacer, flowmaster single out exhaust. any other mods you guys can think of will be helpful. thanks
Old Jun 16, 2007 | 04:16 PM
DamnYankee's Avatar
Default RE: descreened MAF
Don't descreen your MAF sensor. Others that have taken it out have had a lot of problems...but then again some swear it helps. Put it this way - No one with the stock one has problems, in fact some of the fastest non-aspirated trucks are running the stocker. On the other hand there are a LOT of reported problems after descreening due to turbulent airflow. The stocker is designed to smooth the air flow out.
There are tons of other mods you can do to wake that truck up.
Old Jun 16, 2007 | 06:40 PM
hunt4game29's Avatar
I have descreened mine and i have had no problems what so ever. Thanks
Old Jun 16, 2007 | 10:23 PM
DamnYankee's Avatar
See, not all people have issues (or know they have issues). But if you're into performance modifications, you're going to want to get it custom tuned eventually, and I promise you virtually every tuner is going to tell you to use a stock, screen MAF sensor. Whether you can feel it or not when driving it can screw up your A/F ratio, cause detonation, poor gas mileage, etc. Aftermarket MAF sensors are calibrated to operate without a screen. The stock one is calibrated to operate with the screen. If you want a MAF without a screen, buy an aftermarket one. If you screw with the stocker, you will have issues. Search performancetrucks.net and ls1truck.com and see how many issues there are.
Add to that - IF there were gains - they would be minimal at best. Not worth the gamble in my opinion.
Old Jun 17, 2007 | 07:06 AM
MrLM7's Avatar
Use the search window on this page and search "Tips and tricks for Free Horsepower".
Old Jun 18, 2007 | 04:52 PM
smoke20's Avatar
I descreened mine as well several months ago and no issues. Also a slight milage and performance increase.
Old Jun 18, 2007 | 04:59 PM
DamnYankee's Avatar
Those of you who have descreened it - what's your A/F Ratio?
Old Jun 18, 2007 | 11:20 PM
chevy112488's Avatar
mine's running the default a/f ratio (i think thats what argon said), but thats because i have no cats...
Old Jun 19, 2007 | 09:25 AM
MrLM7's Avatar
I removed the screen from mine and I have an Auto Meter AF ratio gauge.The readings didn't change at all from when I still had the screen in.Still right in the middle of Stoich at startup, then bounces back and forth when at cruising speeds, which is normal.
mysilvy
19
Oct 25, 2007 12:10 AM
JohnAdamsR
16
Sep 11, 2007 11:38 AM
airmech_1
26
Aug 25, 2007 03:16 PM
chevyrules
8
Jun 13, 2007 07:38 PM
ShawTownSpecial939
Jun 4, 2007 06:49 PM
