minor add ons
Old Jun 17, 2007 | 12:10 PM
78chev2bnice's Avatar
Member
Default minor add ons
I was just wondering if anyone has ever heard of lifting shackles for a 2002 chev 1/2ton. I'm gettin a little sick of the truck looking like a 2wd and was considering getting a set of adjustable torsion keys from summit for the front. I remember seeing a set of lifting shackles a couple of months ago and was courious if anyone else has ever head of them. I would like to know if I will need different shocks when i add these things. I am also getting a volant cold air and maybe a throttle body spacer. Any additional information would be greatly appreciated.
Old Jun 17, 2007 | 02:31 PM
DamnYankee's Avatar
Default RE: minor add ons
You can also crank the stock torsion bars and bring the front end up some. That's what I did on mine for the same reason - I didn't like how low the front end sat for a 4WD. It MAY affect the wear pattern on your tires. Some guys have problems with that, some don't. I don't in my case....
Old Jun 17, 2007 | 06:50 PM
Member
i've heard that cranking up your torsion bars can cause rough rides, and excessive wear and tear. I found a set of lifting shackles on the djm website but now im wondering if I will need new shocks?
Old Jun 17, 2007 | 07:07 PM
Argon's Avatar
anytime the bars move,it should be re-aligned...as stated,many don't and are fine.....but you are changing working angles
Old Jun 18, 2007 | 05:06 PM
DamnYankee's Avatar
I didn't notice any ride change with mine and had absolutely no problems with tire wear.
Old Jun 18, 2007 | 10:13 PM
Member
Ok so if i crank up the torsion bars whats the most I can get out of them. Also is blocks thewayI should goto lift the truck in the rear?
Old Jun 18, 2007 | 11:23 PM
chevy112488's Avatar
if you go more than two or 2 1/2 turns on the torsion bars, that's when alignment and ride and wear and all that usuallybecome a problem... the good news is, 2 1/2 turns almost levels out most trucks
Old Jun 19, 2007 | 11:42 PM
Member
Ok, so if I wanted to go higher what would be the next step. I was trying to get about 2 1/2 inches of lift in the front and the rear with out spending an arm and a leg. If it costs to much I just wont bother with it. I'm also wondering what people are running for rubber?
Old Jun 20, 2007 | 10:02 AM
stopspazinout's Avatar
just the stocl 2wd rims on some at tires for now. just curious but what kind of block are you looking for. for that 78?
Old Jun 20, 2007 | 04:20 PM
smoke20's Avatar
new torsion keys are the way to go for the lift you want. As far as tires I run 285/70/17 Kumho AT. They last forever, ride good, and are comparatively inexpensive. If I could afford it I would get BFG mud terrains.
