Truck wont start
Old 04-15-2008, 10:33 PM
tayoz00's Avatar
Default Truck wont start
I finally got finished putting the new motor with all the accessories and everything. went to start it wont start. Battery is good. i got the starter connections good. I cant think of any other reason. It doesnt even click over
Old 04-16-2008, 09:25 AM
jcbst12's Avatar
Default RE: Truck wont start
Ignition swich? The interior lights coming on? Battery grounded correctly?
Old 04-16-2008, 09:35 AM
tayoz00's Avatar
no the interior lights are not comming on which is weird but the heat works and front headlights
Old 04-16-2008, 09:49 AM
jcbst12's Avatar
Tailights work? Horn? Turnsignals?
It might be as simple as a bad or misplaced wire. What kind/make/size/year of engine?
Old 04-16-2008, 10:01 AM
chevy112488's Avatar
could be a bad ground somewhere...
Old 04-16-2008, 10:32 AM
tayoz00's Avatar
1992 silverado with a 350 ya turn sighnals work i just got the poweer windows and power locks to work wipers work to and so do rear lights everything except cabin lights
Old 04-16-2008, 10:52 AM
jcbst12's Avatar
If you get nothing on tunring the key, and you are sure the starter is hooked up correctly, check the main ground. Do the idoit lights come on when you turn the key? Sorry for all the questions but I am a little lost on exactly what it could be.
Old 04-16-2008, 11:24 AM
tayoz00's Avatar
yes check engine and everything. Also when i turn on my headlights my windshield wipers come on at the same time and if i turn the lights off they turn off to which is really unusuall
Old 04-16-2008, 12:25 PM
jcbst12's Avatar
There is definately a wire crossed somewhere. I would track down that problem with thelights first. You might find the problem there be it a crossed wire, shared ground or something along those lines. I HAS to be electrical and I am willing to bet its between the ignition switch and the main fuse box. Argon will prob be of more help here.
Old 04-16-2008, 10:30 PM
tayoz00's Avatar
Yes i got it. It was a loose ground thanks for the help guys
propaneman
12-22-2007 10:43 PM
propaneman
10-29-2007 09:59 PM
hunt4game29
08-21-2007 01:14 PM
underoathpac
08-10-2007 04:53 PM
bpollard
8
07-10-2007 04:20 AM
Quick Reply: Truck wont start
