muffler dripping fluid what could be the cause
hi i just changed the spark plugs today it had autolites and i changed them to acdelcos. . . after i started the truck and let it idle a couple minutes i noticed the left muffler started dripping clear fluid, what could be causing this to happen or is it normal. . . .please help. . . .its a 98 chevrolet 350 5.7 vortec truck. . . . .any help is appreciated. . .oh and it fires up quick and idle is stable
i dont think mufflers are suppose to have holes in them cause then that would make it sound like it has an exhaust leak... which if it's leaking from the actual muffler then a little tac weld can fix that... but condensation coming form the exhaust is normal, have you ever been behind someone and see water dripping out of the tail pipe, it's the same thing cept you prob have some small hole in your muffler and some of it is coming out of there... nothing to really worry about.
enclosed mufflers do have holes for the condensation to dip out of otherwise the mufflers will rot out quickly like it did on my 92 chevy c1500 pickup i had. it had those holes but the previous owner replaced the original muffler with a new one and he said he deliberatly plugged the holes because of the drippage and when i got it the muffler was 6 mos old and was starting to rot where the holes were because they were plugged
