my brothers truck is haveing some real major issues
94 gmc sierra ext cab 4x4 5.7 l v8 z71 with close to 300,000 miles
ok fro a bout a year know his truck has developed a problem when you turn the ignition to start it wont start or crank but on the thrid or 4th time it does i put a new battery in it for him also an altenator fast foreward to today -4 with winds of 45 mph he and i are of fwork and he wanted me to lok at his truck told me it wont start at all i checked fro codes and there are non thrown i checked 43 times and even took the battery out and hooked it back up to see if i could trick the compture no luck so i go poking around abit i find his negative terminal bolt on his side post is striped his buddy put in a amp and subs probaly cross threaded the negative when hooking up the battery again this was about 4 months ago so i get ubder the dash and tighten it as tight as it can go without it sliping loose again still wont start also tried to jump start it with no luck i chacked the fuses all is good i checked the battery its got 14 volts im thinking ignition switch or bad ground ssomewhere friday ill replace the striped bolt fro the terminal to see if it helps im going to check power to the starter next the problem is it doesnt crank no trun over or nothing could it also be a fuel pump relay me being stupid trhew away my chiltons so i have to wing it until friday wehn i can purches a new one any ideas would be helpfull thanks |
cubpack, go to this link-
https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL and log in with this- P105200000645 gives you access to EVERY chiltons you could ever want. Enjoy |
thanks
It's a bad starter if you have to turn the key to "start" four times in order to get it to crank. The commutator and/or brushes are bad inside the starter.
Thanks nj85z28 for that info .. I get the same thing through my school, but it's always nice to know about more ways to get online service manuals ;) |
thanks ill check into his starter if so hell be gettin a new one
Mytruck did the same and it was the starter. Actually the solenoid went out but it comes with a new starter.
yep it was his starter soliniod had a loose stud on it it was the one that has the wire going into the starter motor
replaced the starter and took his batter cables off cleaned the ends and converted them into top post terminals cause his batter terminals for the side post were striped out and not tightening so his truck starts like new every time thanks for the help and advice |
I'm glad you got it figured out
well nullhead not quite everything worked on his truck when i tested it and drove it he got in it and started it his wipers wouldnt stop working they turned on as soon as the truck was started and everytime he hits his brake the radio stops working
ive went thru everything idid to it and i didnt cross any wires or anything so know im really stumped any ideas i went thru and made sure everything was tight again also and then his wipers didnt turn on when the truck was started just that his radio goes off when the brakes are applied |
Since the wipers is linked in with the ignition switch harness, I would try that.
| All times are GMT -5. The time now is 03:50 AM. |
