My truck is running like a dog
Old Apr 17, 2008 | 08:52 AM
  #41
rxsteven's Avatar
Default RE: My truck is running like a dog
The engine is running better and better each drive. I think The wrong shift solenoid (or however you spell it) got changed. Im still having trans problems. It dosnt want to down shift when I hit it around 30 and its not shifting into 4th. Im doing 60 and Im at like 2400 rpms I think in going to open the trans today.
Anything I should look for??????
Old Apr 17, 2008 | 10:57 AM
  #42
jcbst12's Avatar
It might be relearning your driving habits. Will it shift at all into 4th? Like 70-75mph then back off of the pedal?
Old Apr 17, 2008 | 11:03 AM
  #43
72charger's Avatar
You could always try disconnecting the battery for a while to reset the ECU. Probably isn't the problem but couldn't hurt to try it.
Old Apr 17, 2008 | 07:03 PM
  #44
rxsteven's Avatar
Tried disconnecting the batt. but its throwing the same code that it did before. I think Im going to try to do it myself. Anyway I had most of the day off (woohoo) so I took alll the trim off, painted the mirrors and smoked my lights. It looks so bad ***!!!!!! Now I want wheels real bad!!
Old Apr 17, 2008 | 10:31 PM
  #45
72charger's Avatar
Hah! You might wanna get it running correctly first bro. Just a suggestion though.
Old Apr 17, 2008 | 10:53 PM
  #46
popo's Avatar
i seem to get side tracked with that too.
Old Apr 17, 2008 | 11:15 PM
  #47
rxsteven's Avatar
popo your back!!! good to here from you again...
Old Apr 18, 2008 | 12:36 PM
  #48
jcbst12's Avatar
Welcome back popo!
Old Apr 22, 2008 | 08:42 AM
  #49
rxsteven's Avatar
Well My motor is running great except for the trans. I fond out I dont have 1st gear thats why I cant power brake and why it dosent down shift when I hit it around 30. I going to try the easy stuff first like checking the connectors and all. If its all good im going to change the solenoid.
Old Apr 22, 2008 | 08:48 AM
  #50
72charger's Avatar
Man that sucks. Good luck with it. Atleast you make the money to get it fixed. If my tranny went I'd be walkin!
