Need help!
Old Aug 16, 2007 | 05:45 PM
tayoz00's Avatar
Default Need help!
hello,
i have a 1992 silverado 350 motor with109,000 milesmy problem is my engine makes a noise like a disel sounds like the hydraulic cam. i just replaced the spark plug wires cuz i thought it was missing but it ddint do it also when i drained my oil i only got like 3 Quarts!!
any ideas ., thanks
Old Aug 16, 2007 | 06:03 PM
gpet6669's Avatar
Default RE: Need help!
Is it a nocking or tapping?
Old Aug 16, 2007 | 08:07 PM
jcbst12's Avatar
Any excessive oil buring like when you go up a hill? Does it dog at all?
Old Aug 16, 2007 | 08:39 PM
tayoz00's Avatar
like knocking sounds like its hitting against something and at idle it runns realllly rough [:'(]
Old Aug 17, 2007 | 12:45 AM
BlackHorse99's Avatar
blowed up
Old Aug 17, 2007 | 07:11 AM
smoke20's Avatar
sounds like you were too low on oil, and as blackhorse said may have blown up. If you are blowing oil out the exhaust that is a tale tale sign that the motor is done.
Old Aug 17, 2007 | 09:28 AM
gpet6669's Avatar
Maybe not the oil out the exhuast giving it away look at the sides of the block and see if there is a hole. That will confirm the diagnosis. Other than that, you are looking at atleast an engine rebuild. That is just a regular 350 you can get them from Kragen's (Checker's or Schuck's) for like $850. pretty cheap for a long block if you don't want to build it yourself!
Old Aug 17, 2007 | 01:31 PM
racethisz71's Avatar
if it sounds like hammers hitting the pistons it detanating because its running to lean check for vacum leaks and clean the mass air that helps a lot
Old Aug 18, 2007 | 10:10 AM
tayoz00's Avatar
so as i went to home depot today the oil pressure droped tolow pressureand i immiedaltly caught it in time and shut off my engine. went to start it wouldnt start[:@]so i think the engine is finally done whhich sux!!.. anyways time for LT1 baby anyone know where i can get a good one
Old Aug 18, 2007 | 10:19 AM
smoke20's Avatar
Have yours made into a 383 with performance heads and cam. It would be fast as hell.
Dawe
Nov 29, 2011 03:05 PM
joebug1956
Feb 18, 2009 10:03 AM
