Need help - Heat problem
Old Jan 17, 2008 | 11:51 AM
Sledog's Avatar
Default Need help - Heat problem
I have a 2001 Silverado 2500 4X4 LT. Occasionally the heat locks on regardless of the temperature setting. Turning the heat control on and off doesn't fix the problem but, turning the ignition off seems to reset it. Dealer says wait for hard failure. WTF? Any thoughts on what needs R/R? Thanks.
Old Jan 17, 2008 | 04:46 PM
Argon's Avatar
Default RE: Need help - Heat problem
both sides or just 1 side?
Old Jan 18, 2008 | 11:16 AM
Sledog's Avatar
I think both sides based on the temperature rise in the cab. It has happened twice so far and I have been alon both times. Next time it happens I will pull over and try to check. Trouble is, it resets when you turn the ignition off (so far).
Old Jan 18, 2008 | 01:10 PM
Argon's Avatar
MOST LIKELY IS AN ACTRUATOR..TRY ANOTHER DEALER,THEY SHOPULD AT LEAST CHECK FOR CODES
Old Jan 18, 2008 | 04:27 PM
legacy's Avatar
I have the exact same problem, i just shut off the truck and it usually fixs itself.
lynx
Sep 3, 2010 04:24 PM
majordad
13
Dec 31, 2008 06:42 PM
Roush08
Nov 19, 2008 05:45 PM
wally91chevrolet
Apr 15, 2008 05:10 PM
majordad
Nov 4, 2007 12:37 AM
