need help narrowing down some problems i have
i have just gone completley mad over my truck the last few days she has pissed me off more times then i can count in the last week
first about a monthago my altenator wuit workin beaings inside were shot wouldnt spin like it should so i caughed up the 140 for the new heavy duty works great
know after hauling about a ton a day my battery light flickers on and off my service light does the same. the lights come on at the same time then off at the same time
i had the local mech check the altanator with is testor it was good its putting out 14.4 volts as it should
also my fuel gauge doesnt work local mech told me it may be the ground on the bed is bad
i thaught maybe it was the float inside the tank that wa bad so i stoped and asked him im not ase cert but i no cars and trucks as i have worked on them since i was about 10
so maybe some one can help me narrow down the problems
i have checked all the body grounds and chassis grounds you can think of minus the fuel pump ground as i my truck is old and has alot of wiring ran to the back for trailor lights
i took the front clip completely off and sanded down every little thing that the grounds went to
and yes they are tight
i dont have anything other than a cb hooked up to my truck
also my reverse lights are out found that out when i got a warning from my local cop
so if anyone has a diagram they could share or some knowlage i dont please share thanks
I'm interpreting that your truck does not have a voltmeter on the dash?
What if you temporarily wired up a meter so that when your battery and service lights come on next time you could see if your new alternator is having a hiccup?
Do you have an aftermarket alarm system on your truck? Sometimes after a couple of years that can start causing problems and have you chasing electrical gremlins. If you do have one, disconnect it from the battery and see if your problems go away.
Check the wiring going to the alternator. The gas gauge is usually the sender itself (in the tank). You can check the ground next to the tank on the frame, but I believe that is only for the pump. For the reverse ights I would start at the tailight and check for power to the bulb, if it does not have power then start tracing baclwards. You state that you have additional trailer wiring - you might have a bad connection somewhere in there. Also, I am not sure what year your truck is, but some taillights had issues with the circuit boards in the light assembly.
my truck has the stock volt meter in the dash and i had the altenator checked out at orielys but i can have someone else take a look
Yeah the 88's were the first year for the circuit boards that burn up. There is probably at least one ground wire that goes to the thermostat housing bolt - give it a look. Definitely get that heating issue inspected. Good luck!
i have a 98 chevy silv. z71 5.7v its newly rebuilt went to crank it and it wouldnt start, poured gas in the throttle body and runs till the gas ran out, replaced the starter, fuel pump gives 65 psi what do i do???? me and my dad r running out of things to try and look at..
also check your fuel lines make sure there is no clogs
but mainly check your coil wire its the one on the distributer that is the smallest one it will go to your distributer then to a coil just a little under the air cleaner
