New Rattle
Old Nov 26, 2007 | 05:32 PM
Z71TwoTone's Avatar
Default New Rattle
I've felt this before in trucks that I test drove, and started to feel it in mine. It's a rattle that I feel through the steering. It doesn't rattle the steering wheel, I'm just able to feel it through the wheel like it is something in the front end. I only feel it every once in a while over certain bumps, and it feels as though something is loose in the front end. Nothing major yet, but I wanted to ask if anybody has experienced this same sort of thing. By the way, I drive an 04 Z71 4x4 ( half ton )
Old Nov 26, 2007 | 06:01 PM
garr58's Avatar
Default RE: New Rattle
I have a 05 crew cab, about a week ago my steering wheel started feeling the same way. It it worse now very clunky, mainly when I turn. I heard its the intermediate steering shaft and you can grease it or replace it. Nobody seems to have found a permanent fix though.
Old Nov 26, 2007 | 06:25 PM
Z71TwoTone's Avatar
Thanks for the tip. I'll check it out.
Old Nov 26, 2007 | 06:27 PM
Argon's Avatar
the NEW shaft (90 bucks from gm) fixes it..don't bother greasing yours.
if you want a temporary fix,unbolt the shaft under the hood and stroke it (insert sex joke here) about 20 times and bolt er right back up.
you';ll be AMAZED!
Old Nov 26, 2007 | 06:37 PM
Z71TwoTone's Avatar
ORIGINAL: Argon
you';ll be AMAZED!
More than likely I'll fix it. I'm not much for the temp-fix. Thanks for the tip.
Old Nov 26, 2007 | 09:21 PM
Lounsbery's Avatar
Z71TwoTone -
Thanks for posting the steering rattle problem! I'm experiencing the exact same thing onmy '06 and was quickly becoming curious as to how much the fix was going to cost .......
Any idea as to how difficult the intermediate steering shaft is to replace? I haven't looked at mine yet and am too lazy to check it tonight .....
Lounsbery
Old Nov 27, 2007 | 05:12 AM
Argon's Avatar
I have no clue of your experience/tools...but its not bad...
make sure you get the GREASELESS shaft from your dealer...the part # ends in 14...
jeff460
May 8, 2008 06:26 PM
chevy112488
Jun 28, 2007 05:56 PM
GMC06
Jan 9, 2007 09:22 PM
desertwest
Dec 27, 2006 12:24 AM
bristolchevy
Jan 1, 2006 07:11 PM
