No power to fuel pump
Old Nov 15, 2012 | 04:33 PM
Eskimojim's Avatar
Default No power to fuel pump
I have a '94 Sierra with a 350. I have no power to the fuel pump. I checked the fuse on the firewall and there's no power to it. I replaced the ECM in the distributer, the fuel pump relay and still no power. I can hear noise when I hot wire the fuel pump fuse on the firewall, but the engine still dosent run with out pouring gass into the fuel injectors. Is it the switch? I don't know. Any ideas? Thanks, Jim
Old Nov 19, 2012 | 01:03 AM
RustyFordLover's Avatar
could be any number of things. Is the check engine light on?
Old Nov 19, 2012 | 08:21 AM
Eskimojim's Avatar
Since I can't get it running the check engine light is on. But at this point I'm thinking it might be the fuel pump oil pressure switch. Will give that a try and let you know. Thanks
Old Nov 19, 2012 | 08:44 AM
Your truck will still run with a fault oil pressure switch. Only diesels WON"T run with a fault pressure switch in my experience.
You need a code reader... There is something telling the fuel pump not to run.
Charles in Oregon
Mar 10, 2013 03:37 AM
ecarri100
Jan 9, 2011 09:54 AM
chrisbmo2000
Dec 24, 2010 03:35 PM
needshave
Jan 24, 2010 12:53 PM
jrk99
Dec 7, 2009 11:57 PM
