| blackhawk17 |
May 6, 2008 08:15 PM |
No spark
Hello all. I'm new here and have an issue with my pickup. It's a 95 Sierra 1/2 ton 4.3 and I'm not getting any spark. I had a miss, so I went exploring and found the no. 4 cylinder plug to be carbon-fouled pretty bad, so that's gonna be an issue. But for now, I just cleaned it off, regapped,and put it back in. I just replaced my plugs about 10k miles ago, so there's no need to replace them yet. I went ahead and replaced the distributor cap, rotor since they were pretty worn. Now, here's where the trouble comes. I got it all back together, plugs in all the right places, and tried to crank. It'll turn over but won't start. I did the spark test and there isn't any. I was getting voltage to the coil, but when I tested the wire from the coil to the ICM there wasn't any. So I replaced the coil. Then, first time I turned the key, it started up. It was really rough so I must have had some wires crossed. So I shut it off. Moved the wires around now it won't start again. I'm wondering if I've got a short in that coil-to-distributor-wire, but I'm not sure. Any suggestions would be appreciated.
