no speedometer and trans won't shift
LMAO. What did I tell ya!??! Something unrelated. And a transmission shop would have never figured that out. They just assume it needs a rebuild. Well now we can be thankful for these forums cuz I have learned so much by them as everyone else has. Glad you got her fixed!!
I had a Ford f-250 that was doing that and it was a speed sensor in the rear end, that in my case came unhooked and didnt let the truck shift. If u have a mechanic that will give u a straight answer for minimal charge it may be easy to check.
Thanks, that was the first thing I looked into figuring that was the problem but didn't work. Issue has since been resolved, I mentioned it in a previous posting in the thread
ended up being the Brake fuse, swapped in a new one (actually there wasn't even one in the fuse panel) and presto! speedo started working and she shifts fine now.
