THIS NOISE IS DRIVING ME NUTS!!
Guys, I have a noise coming from the drivers side back around the area in front of the back tire. It sounds like something vibrating against something else, like maybe the bottom of the truck bed. Does it going over bumps, not on a smooth road. I have been all under the truck checking everything I know to check. Thought it might be a rock on top of something, or maybe the spare tire, muffler hangers, shocks, basically every damn thing. Everything seems to be tight, and can't find any evidence of something thats been moving around. The noise is real loud and annoying. I then thought it might be the leaf spring bushings, but they look o.k.
Anyone out there had this problem before?
No, guys, I already checked that too (the fuel door and pipe, and the u-bolts). They're all tight and not broken. The bottom leaf spring on that side is fanned out, but it's been that way for a long time. I thought that might have something to do with it, or maybe one of the plastic insulators that go between the springs was missing. As far as I can tell they are all ok. I noticed after driving it today that if I hit a bad bump or pothole, the sound changes to a high pitched "ting" like sound. But over bumps that aren't too bad, its a lower-pitched vibrating noise. It's so loud that I can't ignore it. Could this be something to do with the pinion bearing, or axles or something internal in the rearend?
