Noisy driveshaft ?
Old Mar 10, 2010 | 09:41 PM
mjn030's Avatar
Default Noisy driveshaft ?
I just noticed a noise only when I am in drive. It is a scraping noise coming from the underside middle of the truck. I am wondering if it could be the driveshaft or ujoint...
Not sure... 2006 gmc Sierra 2500HD 127K miles.
It is definitely not the brakes !
Any comments on how to check this with out the car in drive.... ?
Thanks in advance
Old Mar 13, 2010 | 01:35 PM
GMC89's Avatar
Hey,
Put the truck on stands, make sure its stable. And put the Truck in drive, You should be able to find out what it is underneath with a creeper.
Thats how i check if my 4x4 is workin on my truck, by putting it on stands.
Hope this helps.
Old Mar 13, 2010 | 01:51 PM
chrisbmo2000's Avatar
A rack is MUCH safer......... you can also climb under it and check for anything that may be rubbing on the drive shaft...i.e. limbs sticks ect.
Old Mar 13, 2010 | 03:19 PM
RUFFNECK4LYFE's Avatar
Look at the carrier bearing. Just get under and move the shaft up and down and watch the rubber.
Old Mar 15, 2010 | 09:17 AM
mjn030's Avatar
Thanks for the info folks !
The problem was a bad ujoint bearing. I replaced it.
Thanks
Old Mar 15, 2010 | 08:15 PM
GMC89's Avatar
Glad that your problem was fixed.
But i do have a comment for chrisbmo2000.
IF!!!! you know how to use jack stands, it is perfectly safe, and if not just as safe to use jack stands as a rack would be.
PLUS, what if some of us do not have access to a rack? or the $ to use one?
Old Mar 19, 2010 | 12:34 AM
Its just the typical disclaimer......but I have to say IMO jack stands are not as safe as a rack...and yes I understand not everyone has access to a rack....again its just a disclaimer
Doggy-Dog
Jul 17, 2011 06:55 AM
chevyrules
Nov 16, 2009 08:30 AM
bindavid
Sep 30, 2009 10:53 PM
HSV Madman
Aug 5, 2006 01:24 AM
bristolchevy
Jan 1, 2006 07:23 PM
