Noobie - First Post - and A/C Issue
Hey everyone! I'm th enewest member of the forum, and wanted to introduce myself to everyone, as well as hopefully get some advice about an issue that I'm having.
I have an '04 GMC Sierra 2500HD, and its a great truck - I LOVE IT! Last year I installed a NAV system out of a Yukon, along with a 6 disc changer - thats the best upgrade ever!
I'm having an issue with my A/C that I'm not sure what to do with. I like to work on my truck myself as much as possible, but I know next to nothing about the AC ssytem (I guess nows as good a time as any to learn
I turned on my A/C today, and its blowing hot air - very hot air. Its an auto climate control, and even though I have it set to the lowest possible temp, its blowing air hotter than I've ever had it blow before. The compressor still kicks on (I heard/felt it) but no cooling at all.
Does anyone have any ideas, or suggestions - things I might be able to try before I take it in to get raped by the dealer?
I looked through all of the posts for anything about this issue, but didnt come up with anything.
Thanks!
)I turned on my A/C today, and its blowing hot air - very hot air. Its an auto climate control, and even though I have it set to the lowest possible temp, its blowing air hotter than I've ever had it blow before. The compressor still kicks on (I heard/felt it) but no cooling at all.
Thanks!
Its not the cycling switch if the compressor comes on.
The temp actuators are out of range...try disconnecting the battery a few minutes...then fire it up,and toggle the temp settings from 90 to 60 a few times
Thanks Argon - I'll give that a shot.
I actually had an issue with the battery a couple of days ago - one of the cables had come loose and everything dies when I turned it over.
I tightened up the cable, and everything went back to normal, but I hadnt used the A/C since then.
I 'll keep you posted.
Thanks!
Thanks!
