not front pinion seal?
Old Apr 20, 2008 | 06:46 PM
Randyman's Avatar
Default not front pinion seal?
my front differential was leaking gear oil. so i took off my drive shaft and all and took the seal out.. well i go up to every auto parts store local and noone has the same seal, and they keep telling me that the book says i should have bearings... either way all 4 stores i went to tried to match it up for me none matching and the part number on the seal isnt showing up on their computers
I am assuming i have an aftermarket front differential or it was a swap Should this be the case how can i find out what front differential i have?
And if for some odd reason mine is stock and anyone else has had this situation and can help... I have an 01 silverado 1500 reg cab, shortbed stepside, z71
Old Apr 21, 2008 | 07:18 AM
Argon's Avatar
Default RE: not front pinion seal?
huh?
there has to be a bearing and a seal..
this is where the front driveshaft bolts up to the front flange,right?
Old Apr 21, 2008 | 10:55 AM
Randyman's Avatar
my thought exactly but all the auto shops here were telling me that its not showing a seal... I have solved my problem i went to the dealership and they had it and i now have it fixed i was just hoping to have this problem fix yesterday. Thanks for the reply Argon
A1Recovery
May 19, 2014 11:38 AM
olz442
Feb 20, 2011 07:41 AM
smoke14
Apr 29, 2010 10:09 AM
Jaybow
Nov 10, 2008 06:10 PM
nhbp06
Jul 2, 2007 05:51 PM
