Oil gage
Old Apr 26, 2008 | 07:58 AM
topknotch06's Avatar
Default Oil gage
All right... my oil gauge has been bouncin around for the past week... i believe its for the oil temp... right or maybe the compression... either way its regular when idleing and when running it shoots all the way to max... is there a sensor i need to replace or ???? anyway appreciate any help thx...
Old Apr 26, 2008 | 09:49 AM
72charger's Avatar
Default RE: Oil gage
I'm thinking it's probably a bad oil pressure sending unit. Could be the gauge is just bad but probably not. Usually the sending unit is something like $20ish if I remember correctly and also requires a special socket for removal which any parts store will carry. Good luck with it man.
Old Apr 26, 2008 | 05:47 PM
wellmax's Avatar
Member
also put a mechanical gauge on it, be sure the oil pressure is correct as low or no oil pressure will kill the engine faster than anything.
Good luck,
Old May 14, 2008 | 02:31 PM
thanks.;.. ill swith out the oil pressure sending unit... but any nidea where its located at??????
Old May 15, 2008 | 12:10 AM
72charger's Avatar
uuuuum.... it's on the engine somewhere.
JAKE_GMC_350
Jun 22, 2010 08:10 PM
dwhite1957
Nov 6, 2008 06:09 PM
guic
Aug 25, 2008 03:25 PM
christinia9
Dec 5, 2007 04:23 AM
ldstockwell
Dec 10, 2006 01:41 AM
