old truck wont start :(
Old Aug 17, 2011 | 03:39 PM
Wiked's Avatar
Default old truck wont start :(
i tried to start my old truck to hera the open headers and it cranked fired once and dies and keeps cranking also the voltage suckes even though its a new battery and connectors
maybe since i took the hood off and maybe water get in somewhere? but i always kept the engine covered with a tarp
Old Aug 17, 2011 | 03:56 PM
ben h's Avatar
is it getting gas?
also check to see if its sparking
is it carbed pump the gas or just hold it to the floor
Old Aug 17, 2011 | 06:28 PM
NullHead's Avatar
What engine? My 5.0/305 doesn't crank for long until it slows down. It's got like a 750cca on it I think.
If it's TBI, then pull the air cleaner and look down the throttle body and have an assistant crank and look for fuel. If you've got fuel, then it's spark. Check for spark. If both present, perhaps bad fuel, low compression or not enough fuel and a regulator or pump issue.
Old Aug 17, 2011 | 07:26 PM
Wiked's Avatar
its got spark and i have no clue where or how to check my regulator
its a 4.8 and i know its good gas because it was running the day before and ran very nice
Old Aug 17, 2011 | 07:31 PM
MrDragon's Avatar
What year and what motor? If it's cranking weak, I'd almost say starter but you said it did start amd crapped out so I'm gonna guess maybe a control module. Ps, they don't like water.
Old Aug 17, 2011 | 07:33 PM
Wiked's Avatar
its my other 99 4.8
but the starter works great! its cranks fires once then quits
Old Aug 18, 2011 | 04:32 PM
Wiked's Avatar
i had an epiphany to use ether in the throttle body
Old Aug 18, 2011 | 04:35 PM
NullHead's Avatar
Well what did it do?
Old Aug 18, 2011 | 04:43 PM
Wiked's Avatar
no clue i have to run out and go get it.
im also going to pick up a new relay and see if that does anything
Old Aug 19, 2011 | 01:35 PM
Wiked's Avatar
All my relays and fuses are good
Sprayed ether and it ran good for 5 seconds so it must be fuel? But all the fuel relays and fuses were good Or can a MAF sensor do this because I was toying with thatt thing
