P0137 code
Old Oct 7, 2010 | 09:00 PM
ridefree83's Avatar
Question P0137 code
sorry if this is a repeat ? but I could not find this topic listed.
I drive a 96 Chevy c1500 5.7L v8...
So I was recently I replaced my bank 1 sensor 2 O2 sensor.
After changing it the check engine light did not got out. (disconected the battery to reset). So ran to A-Z to find out what the code was and got P0137.
I checked the wires visually and there are no cracks or worn parts. Also used a voltmeter to see if there was a drop in the wires and there wasn't. So I am confused as to why I am getting a low voltage during the scan. Could the O2 sensor be bad? The cat. was replaced <5k mil ago and there are no exaughst leaks.
Any ideas on what I could check?
Old Oct 7, 2010 | 09:39 PM
rmck490's Avatar
Here's some info that might help:
http://www.obd-codes.com/p0137
If you are still getting the same code after replacing the sensor, I'm betting it's an open or short in one of the O2 harness wires somewhere.
Old Oct 8, 2010 | 10:45 AM
ridefree83's Avatar
thanks for the info. I used my voltmeter to check the harnesses and there were no problems there.
A buddy of mine said that sometimes this could be caused by a bad fuel pump. Is that possible?
goalee29
Jun 7, 2009 02:15 AM
iascum
Jul 26, 2006 12:05 AM
iascum
Apr 20, 2006 02:03 AM
klrjoe
Dec 7, 2005 05:32 PM
montero91
Dec 7, 2005 01:31 PM
