Please any help on Posi traction
Old Jan 9, 2007 | 10:55 PM
  #11
scauntay's Avatar
Default RE: Please any help on Posi traction
if your front wheels are spinning faster than the rear wheels, that is not good and you should get that looked at pretty soon.
Old Jan 10, 2007 | 01:08 AM
  #12
imbroke's Avatar
I tried to check the front tonight. when in the air I could not even budge the driveline. If I turn the tires it does nothing to turn the driveline. Weird. hard to say what is going on. My ahave to breakdown and do it the expensive way
Old Jan 10, 2007 | 03:28 AM
  #13
scauntay's Avatar
did you make sure it was in neutral? ive done that on my camaro when i lifted the rear to see if it still turned. the wheels wouldnt turn more than an inch and i couldnt figure it out. then i realized it was in park.
Old Jan 10, 2007 | 04:03 PM
  #14
imbroke's Avatar
yep in nuetral, I did the same thing only in drive but I tried it everywhich way. Defintiley something messed up
Old Jan 10, 2007 | 09:21 PM
  #15
smoke20's Avatar
Did put the transfer case in nuetral also? or just the tranny.
Old Jan 11, 2007 | 04:03 PM
  #16
imbroke's Avatar
when you say that you mean actually in 2wd so the front can turn right? so the front transfer is in nuetral? IF so no and now that you say that it makes sense Ill try it again, and again,,,,,, and again
thx for the help
Old Jan 11, 2007 | 07:08 PM
  #17
smoke20's Avatar
No I mean actually in nuetral on the tranfer case right off the tranny. You are thinking about the front differential.
TheMan21
10
Aug 28, 2008 01:12 PM
SouthBayZ71
13
Oct 3, 2007 11:37 AM
91CHEVYSILVERADO355
Sep 20, 2007 05:04 PM
GMCJohn
Nov 29, 2005 02:16 AM
clblack3
Jun 28, 2005 04:20 AM
