Power Lock not working since I repaced Outer Door Handle
Old Mar 16, 2008 | 12:14 PM
Joneebgood's Avatar
Default Power Lock not working since I repaced Outer Door Handle
1999 Silverado NBS
I replaced a broken outer door handle and now my power lock on that door doesn't work. The solonoid still clicks and the door will lock if you manually move the lock slide so the rod is still connected but the solonoid will not move the rod that connects to the lock slide. I guess I must have dislodged something but I sure don't see anything out of place.
Does anyone have a good photo or diagram of the power lock mechanism and the rods? Maybe if I understood how it was connected I could see what I messed up. I just can't see far enough into the door to figure this out.
Thanks for any suggestions.
Old Mar 17, 2008 | 09:52 AM
gpet6669's Avatar
Default RE: Power Lock not working since I repaced Outer Door Handle
There is a rod that is not hooked up in the door. I did the same thing two years ago and then again last year. (had to replace the outside handle then the inside one) Just look in there and you should be able to see what I am talking about. Tear it apart again!
ipMdycguir
May 28, 2021 12:29 PM
jt41time
Jul 5, 2013 09:35 AM
billie
Mar 10, 2009 12:33 AM
hunt4game29
10
Oct 4, 2007 03:21 PM
MrLM7
10
Apr 7, 2007 02:37 PM
